Arc into segments
Command |
Path |
Arc into Segments |
Modify > Drafting Aids |
The Arc into Segments command converts a selected arc or circle into an equal number of segments, or divides the arc or circle into segments of a given length. The segments can be drawn as lines or polygons; the original object remains unchanged.
To convert a circle or arc into segments:
Select the arc or circle to be converted.
Select the command.
The Arc Into Segments dialog box opens.
Parameter |
Description |
Method |
Number of Segments |
Draws the specified number of equal segments along the arc |
Segment Length |
Draws segments of the specified length along the arc |
Options |
Draw Polygon |
Draws the segments as polygons |
Draw Lines |
Draws the segments as lines |
